Howdy!
I am trying to set a mixed DVD included both the movie and
the soundtrack from the movie.
I am using DVD-Lab:
The movie "Electric Dreams" comes with this filestruture:
\VIDEO_TS
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
The soundtrack comes with this filestruture:
01.wav, 02.wav, 03.wav.....10.wav
1. Create a new project using DVD-lab
2. Set properties for ROOT
(a, b selections in ROOT)
a. Play move (goes directly to Movie 1)
b. Play the soundtrack (goes to a new meny
where I can select slides from 1 to 10.
d. Make the slide, import the 01.wav to Slide 1
e. Set picture for Slide 1
f. Import VTS_01_1.VOB, VTS_01_2.VOB,
VTS_01_4.VOB, VTS_01_4.VOB
(Use it directly without Demultiplexing)
g. Draw a links. Included links between VOB-files
h. Save and compile...
?? Did not work
- Will not play the next VOB
- NOSOUND when playing standalone DVD. (Centrum Gemini 330)
+ When playing using PowerDVD all worked silcky smooth.
- Do I need to merge all VOB-files, first?
- Do I need to setup properties for VOB-files using
IFOedit or VOBedit?
For last I know there is some rules how a Standalone DVD will
play when reading info from VIDEO_TS.IFO and VTS_01_0.IFO
but why does it work using PowerDVD?
Thx in advance,
Besk
Results 1 to 1 of 1
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 4th Jul 2011, 23:15 -
Mixed Multi Angle DVD Encoding Problem
By werdna1900 in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 04:32 -
How to make a mixed DVD
By Baldrick in forum User guidesReplies: 60Last Post: 4th Sep 2008, 13:01 -
OK to output mixed project as progressive?
By stantheman1976 in forum Video ConversionReplies: 6Last Post: 16th Jun 2008, 14:38 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
