Hello,
I am having some problems here with Adobe Encore. I was wondering if any one has had the same problem and knows how to fix it.
I create all of my videos in Adobe Premiere Pro. This program allows you to create titles with either still, rolling or crawling text. Once they are created they can be placed in the timeline. I normally use the default timeline which has 3 video tracks and 3 audio tracks. Once I have created my movie render it and export it to a selected folder as an .avi file. I watch it and it plays exactly like i made it.
Now I use Adobe Encore to create menus. I import the movie as an asset and link it to a button. I then select preview to check to see if all the links are set correctly. However, for some reason some of the titles that i had created in premiere don't play like they should. some will only flicker. If the tittle was set for a duration of 7 seconds, some will only show for like 0.1 of a second and the screen is black for the next 6.9 seconds. You can't even see what it says. this only happens when i preview the movie in Encore and also this is exactly how the DVD comes out. I have tried moving the titles around to different video tracks in Premiere and re-rendering the video which is time consuming. Some times this will fix it. It seems asthough title video can not be on the same video track as the raw captured video. Not all titles flicker though. Some are good and fucntion just like i created them. i dont' get it.
As i mentioned before, when i just play the video in Windows Media Player if fucntions normally, exactly how i created it.
Does anyone know why this may be happening? It is starting to drive me crazy. Anyone who knows Premiere knows that you can spend hours screwing around with titles and when they don't work it is very frustrating. Any information on how to correct this problem would be wonderful. my intuition tells me that the problem is with Premiere however i am really not sure.
thanks for your time,
fasterisbest
Results 1 to 12 of 12
its a problem with Premiere , just one of the many bugs i understand ..
I just hate it when I lose my tittles.lost tittles when authoring in Encore created in PremierePro
Don't go around saying the world owes you a living. The world owes you nothing. It was here first. - Mark Twain
Tolerance is not a virtue. Only the intolerant demand tolerance of everyone else. -
the encoder (main concept) built in pro is excellent ... in fact its superb ..
I've heard of the same problem when using Premiere generated file in DVD Workshop as well.
I use both Premiere Pro and Encore for DVD design and I've NEVER had problems with titles in over 70+ complete videos.
Nor have I ever had any issues with Encore not accepting Premiere's mpg2 files.
Why mess around with creating .avi's in Premiere anyway if you are going to DVD? -
Thanks for all the input everyone. it has helped however i am now having a problem with the audio. I export my movies from Premiere in
MPEG-DVD format and import them into Encore and now there seems to be no problems with titlles. however, i have no audio. I have tried PCM, MPEG and 5.1 audio coding and still have had no luck. any ideas on what the problem may be.
any input would be great.
thanks for your time. -
What are you using to play the file? Is there audio when you play it in windows media player? Are you sure the file is muxed, and that you aren't just playing the video part by itself?
if you mean when you play the dvd ... did you remember to use 48khz sample rate ?
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 30th Apr 2012, 00:24 -
Authoring Blu Ray in Encore
By Vasilis in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Nov 2011, 13:44 -
Bluray Authoring with Adobe Encore
By jrodefeld in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jun 2011, 20:06 -
export subtitles created/synched in Authoring Works
By ecc in forum SubtitleReplies: 1Last Post: 21st Feb 2009, 19:44 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 08:30
