Whenever I make a dvd with nero, the ff/rw never works on either of my standalones...
is there a value i can edit somewhere in an .ifo somewhere to fix this?
Results 1 to 11 of 11
Have never had this problem with Nero, only with Sonic MyDvd ver 3.5 , the problem seemed to trace back to audio used by sonic.
What are the file properties?
I also have NOT used Nero to author, just to burn -
The player rejects the speed of the recordable disc in use. Has zero connection to the burn or Nero.Originally Posted by yodandyWant my help? Ask here! (not via PM!)
So does anyone know how to get ff/rw to work on svcd to a dvd?Originally Posted by yodandy
I had been frustrated with this problem for some time no matter how and in what software I used to create my DVD's. When trying out the TMPGEnc DVD authoring software it choked on my MPEG2 files telling me that to be compliant they needed a sequence header before every GOP. I went into my encoding software and made the change and viola fast forward and rewind work just like they are supposed to.
Hope this is of help . . . -
Has something to do with the IMPLEMENTATION of the DVD spec in the particular authoring platform your working with.. (but you knew that)
What I've found
Programs that allow ff rew
Sonic DVD Architect
Adobe Encore
Spruce UP
Programs that bite
My DVD
Sonic Reel DVD
DVDit LE and SE don't know about PE
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 07:16 -
Sumvision Phoenix will only fast forward or rewind some files.
By muay in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2011, 08:01 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 16:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 28th Jun 2008, 00:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 22:48
