Hi often, I believed it's because of copy protection that VOB files on DVD has CRC errors which stops program such as DVD Decrypter, or Smartripper, AnyDVD, DVDShrink from reading the files. Is there any programs out there that ignores the CRC error and copy/ripped the VOB file?? Usually it's just 1 VOB file with a CRC error that prevents the whole movie from being ripped. As long as I can get all the VOB onto the harddrive everything will be fine.![]()
It a bad spot on the media. It cannot read it.
I believed that is so too, but I was wondering if there's program out there that ignores the bad spot and continue with the rest of the VOB file? Because often the VOB file is 1.2GB and just a small bad spot prevent it from being copy, which prevent the whole movie, which is a great nuisance. This file is VTS_01_3.vob. And if I played this disk in any DVD player or Powerdvd it still plays fine. Just that it can't be copy because of that bad spot. I need a program that ignores the tiny bad spot and continue with the rest of the file. As long as it's on the hard disk, it can be reprocess. Thanks.
ISOBuster and lots of luck
DVD X Rescue will recover troublesome DVDs like that. I have used it on several and it worked perfectly. Probably overpriced for most people ($50.00) but it does work.
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
Crc error
By Hell Bound in forum DVD RippingReplies: 6Last Post: 6th Nov 2010, 06:00 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
Help Cannot Unzip Last File CRC Error
By mn072065 in forum ComputerReplies: 16Last Post: 18th Jul 2007, 09:48 -
damaged file(crc error) how to get it off dvd
By invadar in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 08:59
