I was trying to convert a (PAL) DVD to SVCD. The clip (see image) appears to be interlaced.
It would be nice if I get get the SVCD to be watchable on a computer monitor as well as on tv. Then it has to be de-interlaced, right? So I checked the Deinterlace box in ffmpegX 0.0.9a. The result was not that great. Some horizontal striping remains (see image).
Is it the quality of the filter? Am I trying something impossible? Or am I missing something? Any suggestion would be welcome.
Results 1 to 13 of 13
AnonymousGuest
1/ Try to activate "Single field" in the high quality properties window of Quicktime Player (and hit apple-S to save).
2/ If this is not enough, enable both "Deinterlace" and "Denoise" in the ffmpegX options.
AnonymousGuestThere is no such option to activate for VOB and SVCD files.Originally Posted by major
With both options enabled, the output still looks the same.Originally Posted by major
AnonymousGuest
Yes, the deinterlace options in VLC do deinterlace the movie quite well.
AnonymousGuest
I used the MPEG4 [.AVI] (mencoder), which seems to be DivX 4.1.2, and encoded to 480x576 for comparison with the SVCD setting. The deinterlacing worked as advertized! Yeah! Does this mean I have to do DVD > DivX > SVCD to tackle the deinterlacing? On a sidenote, I also noticed a much brighter picture (see image) than before, although I didn't touch the luminance setting.
AnonymousGuestAh, okay. The DivX 5.1 Pro QuickTime plugin (DivX Pro 5.component) identified the video of the avi as "DivX 4.1.2", hence my assumption.Originally Posted by major
I'm working a little more on 0.0.9b, though improvements on SVCD deinterlacing will not be included in that version.
I work as follows: "as soon as I have time, I work on new versions, and, as soon as I finish a new version, I release it", as you can see there are two indeterminate variables.
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
How to know if a video is interlaced?
By JLGUT in forum EditingReplies: 9Last Post: 20th Mar 2009, 15:40 -
Captured video is interlaced - Help?
By dave_van_damme in forum Newbie / General discussionsReplies: 8Last Post: 25th Feb 2009, 16:44 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03 -
How can I tell if a video is interlaced?
By cheerful in forum Newbie / General discussionsReplies: 10Last Post: 18th Jul 2007, 21:56
