hi im new to this just wondering if there is anyway you can put avis onto a dvd also my friend using bit torrant has anyone heard of this i had a quick look at guides and was unsure which one to use i would be most graefull for any help thanks. i have a pionner dvd writer with nero burn software
You can make a data cd using nero easily, just open nero and go to "file" then "new", select DVD on the top for compilation, then "dvd-rom iso" drag and drop your files there and make a data cd. Thats how i store most of my files too, since cdrs are only a measly 700 megs and are just incredibly expensive when compared to dvdr. If youre talking about reencoding your avis to be dvd compatible i personally dont see the point, you wont get better quality.Originally Posted by jay005
For bittorrent i use "BURST! which is avalable at:
http://krypt.dyndns.org:81/torrent/download.phtml
To find torrents you can start at places like suprnova.org, filesoup.com and bytemonsoon.net -
Because if he doesnt reencode and author, then he will not be able to watch the movie in his dvd player, if that's what he is wanting to do.Originally Posted by Moloko_Plus
SLICK RICK
Originally Posted by lordsmurf -
Beats me why everyone says whats the point of converting AVI to DVD-r.
Well the major reason is that most DVD players i have seen and used can read DVD-r but not AVI files on a CD. (Unless converted to VCD/SVCD).
The only way to watch AVIs is on a Compie but if the film is on DVD well i'm sure people can work that out.
As more people have DVDs than Compies i think that answers the question of "Why convert AVI to DVD-r".
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
