hi i just done my 1st rip with dvd encrypter and then conversion with dvd2one it all went smoooth opened nero up and done as the guide says
and when i went to burn says disc not big enough 4.7 gb dvd-r well it was all done too fit on 1 disc plzzzz help desperado thanxs
Results 1 to 16 of 16
What is the complete size of the video files you are trying to burn to dvd?
SLICK RICK
Originally Posted by lordsmurf -
While Nero is open, hit the Prt Scr button and paste it in PaintOriginally Posted by winny22
save as JPEG and post the pic here.
SLICK RICK
set on full disc and version 1.2.3 and when i save as j.peg its too big to post 117 kb only post on ere as under 50kb
DVD2One allows setting the target size for both movie only and full disk conversions. Mine, when starting, has a default size of 4472 for full DVDR(W) disk size, which has never failed recording.
On the other hand, the size of a DVDR(W) is 4.36Gb, which is the same as 4.36 x 1024 = 4464.
Perhaps you should change the default setting to 4464 or even slightly less than that (e.g. 4400) to make sure the result will fit on the target DVDRThe more I learn, the more I come to realize how little it is I know. -
ok sasi ill try that in the morning thanxs all u guys keep an eye on this post if it helps me it helps a lot of ppl l8er cya in the morning
(you probably said this already, but...)
is it a dvd+r or a dvd -r? From past experience, I can tell you that dvd+r's hold a tiny but less data than dvd-r's (a few mb's). So...yeah.-Yar, matey!-
Full screem mode
By sat-jokar in forum Video ConversionReplies: 3Last Post: 29th May 2009, 09:36 -
Making an audio CD on Nero
By orfajackson in forum Newbie / General discussionsReplies: 5Last Post: 12th Apr 2009, 17:03 -
Nero vison dvd making
By Connscience in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 00:29 -
Nero 6 and Making a Photo CD
By solarblast in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2007, 12:56 -
Nero 7 is making movies bigger than they should be...
By Harkonnen in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 02:59
