  1. Maybe someone out there can help with this;
    I have been using dvd2one 1.3 to compress my backups. Recently, the program is producing files larger than 4.5gb. I am using the DVD+ settings at 4472gb. and full disk. all the settings are the same as they have been. this happens mostly with new discs and not 100% of the time.
    I searched the forum and found similar problems, but not quite the same. Has anyone experienced this, and do you know how to fix it?
    Thank You,
    Mike
  2. Have you tried going to DVD2one's forum for a resolution?
    I have been using the same version you're using without any problems(so far knock on wood!!)
    Might want to try this link:
    http://www.dvd2one.com/forum/viewtopic.php?t=268
    Hope it helps!Good Luck!
    Oct 2003
    Central Texas, USA
    While I initially used DVD2One set to 4472mb, I've now dropped it down to 4450mb. I've seen a few posts similar to your own where 4472mb was a little too big, so I decided to do my best to avoid the problem altogether. I supposed that some media is pretty iffy as far as space goes, resulting in an occasional issue with space. Try dropping the size down to 4450mb and I bet the problem will go away.
