I have to capture to MPEG2 via s-video (would like AVI, but cannot - using Sony Vaio PC)
Edit (clipping mostly) using Screenblast MovieStudio 3.0
Render to MPEG2 using Screenblast
Author and burn using Ulead Movie Factory 2
Yes?
Thanks,
Allen
Results 1 to 13 of 13
If you have already captured it to MPG2 then you do not want to render the file again. You can simply cut out the parts you don't want, but don't render again.
Why aren't you capturing to AVI? Is it a disk space issue?
LS -
If the only editting you are doing is clipping the odd bit out, why not use Movie Factory to do the lot?
Good questions: I am capturing to MPEG2 because that is all my Sony Vaio has capabilities of capturing to.
I am not sure about the answer to the not rendering again question. Are you suggesting that after editing the MPEG2 file I can go straight into authoring?
Really?
I am not using Ulead for the editing because I have read that their tool to create files to author are not that great.....Screenblast has a better tool. That being said, perhaps I don't have to even use Screenblast if I don't have to render again...although I am not really sure what I am talking about.
Allen -
I used to capture to avi- usually took 6-7 hours to render to mpeg 2 after editing.
Now I capture to mpg2- takes '0' hours (and '0' minutes to render), and about 20 minutes to compile a DVD in TMPGEnc DVD Author.
Unless you're doing a lot of serious editing, why would you want to capture to avi when you're going to have to convert to mpeg2 anyway? -
Bob,
I hear ya, but how do you edit? Using TMPGEnc DVD Author? As I mentioned, for editing I am really only cutting out sections.
Then how do you burn? -
It's very easy:
1. Load your mpeg
2. Click on edit
3. Find the beginning of the part you want to cut out
4. Click on Set as start frame
5. Find the end of the part you want to cut out
6. Click on Set as end frame
7. Click on Cut -
Sorry for my ignorance, but I assume you are referring to using TMPGEnc DVD Author. yes?
So after I capture in MPEG2, I open TMPGEnc DVD Author, edit out what I don't want then add chapter points (Authoring), then render and finally burn...all with TMPGEnc DVD Author? -
I am not clear in what I should do.....
I am capturing in MPEG2.
I edit using some tool (MS3, MF2, TMPGEnc DVD Author)
I save as MPEG2???
Then author (add chapter points) using MF2 or TMPGEnc DVD Author???
Then burn.
Again, sorry for the ignorance, and thanks for the help.
Allen -
Originally Posted by BobK
The real question is: after editing in either MovieStudio or MovieFactory, can I save it as an MPEG2 file, then author in MF, then burn - essentially skipping an additional rendering step?
Allen -
Originally Posted by vwcrusher
So,
1. Capture.
2. Open in TMPGEnc DVD Author.
3. Do cuts and select chapter points.
4. Burn. -
mrmungus,
Wow, thanks very much for dumbing it down for me.
Thats a great solution!
So I really don't even need Screenblast MS or Ulead MF?
Allen
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 21:58 -
Trying to convert MTS files to something reasonable for website
By Newmomma in forum Video Streaming DownloadingReplies: 5Last Post: 30th Jan 2011, 11:52 -
upgrade video card reasonable?
By gooberguy in forum ComputerReplies: 2Last Post: 23rd Apr 2009, 11:00 -
Good DVD Recorder with internal hard drive at reasonable price
By geek2330 in forum DVD & Blu-ray RecordersReplies: 30Last Post: 1st Aug 2008, 04:15 -
Process flow - VHS to DVD - am I on the right track????
By stixx in forum Newbie / General discussionsReplies: 7Last Post: 19th Dec 2007, 15:06
