hi
i convert my audio and my video separately from an avi file and the 2 files doesn't have the same longer in time. Why ?
I have audio problem so i'm asking myself if it's not the problem
do you no a soft to cut mp2 files?
Which encoder do you use?
I assume it is TMPG. When you encode the audio, select both video and audio source, make sure, the framerate is correct, and then select "audio only". So you will avoid sync problems.
Muxing Longer Audio Track than Video
By Tony Jenkins in forum AudioReplies: 2Last Post: 4th Apr 2012, 14:15 -
Problem with WMV files with longer audio than video
By Jumpe in forum Video ConversionReplies: 2Last Post: 26th Jun 2009, 14:00 -
audio way longer than video
By sn0wd0g in forum DVD RippingReplies: 5Last Post: 14th Jul 2008, 01:58 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
FLV Video Longer Than Audio... How to Re-sync ?
By Babalou in forum Video ConversionReplies: 9Last Post: 16th Apr 2008, 13:43
