I always get such a dark shaky image when I'm recording my home video to the HDD of my panny e80. I read through some posts in a couple of forums and learned that should use Component cables and to change the black level to lighter on output. I have been using s-video previously.
Well, it turns out after I buy my component cables last night that it doesn't work because my television does not support Progressive Scan. Does this sound right?
So I went back to s-video and switched all inputs and outputs to lighter. I still don't see much difference.
Is there anything else I can do?
The picture on the LCD of my video cam is so clear and colorful, is it because it's such a small screen? I wish it would look that way on my tv screen.
I would appreciate any suggestions.
Thanks,
Andry
Andry
Panny E80H & Sony DVD300 Camcorder -
play it back on another tv ... as a tv gets older - they do get darker ...
But my Tv is Brand New! It's a Panny as well and it's a flat screen (not Flat Panel) 27".
Any other suggestions?Andry
What you need to do is go to the setup menu and change the component output from progressive to interlaced and it should do the trick.Now does this happen when you try to record from a vcr? If so what you are getting is a macrovision signal.I hope this helps..
How to progressive Upload video & progressive download
By video909 in forum Video Streaming DownloadingReplies: 1Last Post: 6th Mar 2010, 05:17 -
Progressive Scan for DVDs
By KayAt in forum Newbie / General discussionsReplies: 9Last Post: 25th Nov 2008, 21:30 -
Progressive scan problem
By Deaner777 in forum Authoring (DVD)Replies: 0Last Post: 28th Jul 2008, 15:23 -
Two Questions - Progressive Scan & DVCAM...
By gavfreed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jul 2007, 11:26 -
Confused about progressive scan
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2007, 12:28
