Ive played loads of vcd's on my pioneer dv-626d with no probs but I'm having troubles with the latest one I have burnt. It plays for about 5 mins then just stops playing. It plays fine one the pc with power dvd. Then I noticed that when the film is burnt it's split into 3 parts, and the part where it goes off is the end of part 1. Should it be in 3 seperate parts? All the vd's I have made in the past have been one large file. I created it with a bin and cue, so maybe the cue was incorrect.
I did try converting it with vcdgear and then joining into one file with tmpgenc but got a error saying the second part had no video stream.
Am I being totally thick is there a solution.
More info is needed for an accurate prognosis. What did you burn it with? Were you using a cue file to do chapters? have you compared this cue to others that have worked? Do you still hav the source files, and if not, can your disc be ripped and rejoined?
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 01:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
