I thought I'd share some of my experiences with trying to cut some Mpeg2 files. Since I'm a newbie I think this may be helpful for other people like me.
I downloaded a few files that were in a cue/bin format and so called "SVCD" format. I wanted to get the actual MPG out of it so I used "Isobuster" to extract it.
Joining:
I followed the instructions on this site to join files using TMPGenc but I found that it screwed up the audio synching royally. So I scrapped that idea.
Cutting:
Also using TMPGenc I tried the instructions on this site to cut a file. I found that it would not cut the file at the place I wanted. The audio would stop at that correct point and then play some silent video for 10 seconds afterwards. I tried this many times to the same effect and got fed up with it.
So I downloaded BBmpeg and tried that it worked well! Cuts at exactly the place I wanted both audio and video. I used the instructions on this site where it tells you to use TMPGenc to demultiplex the stream, then use BBmpeg to cut. Simple as that.
Anyways, thanks for the helpful information here. BTW, for those of you who also download "files" from Usenet doesn't it bother you that the "files" are formatted to fit on those new 90minute/800mb CD's? I have an older CDR so it won't support them and where I live I don't think 90minute CDR media is readily available. Just an observation and the motivation for me to play with this stuff.
Results 1 to 1 of 1
clumzy
I have editting questions
By wolfspirit1964 in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2010, 21:15 -
Converting HD 60fps MOV files for vegas editting
By 41i3n777 in forum Video ConversionReplies: 4Last Post: 21st Dec 2009, 19:37 -
Combining Sony mpeg2 files with m2ts files
By hsid in forum EditingReplies: 8Last Post: 2nd Mar 2008, 20:51 -
PC for HD editting
By Olivier_14 in forum ComputerReplies: 4Last Post: 26th Feb 2008, 13:02 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03
