what would be the most-likely reason? The MPEG-2 files I capped have perfect sync. The VOB's, played on WMP or burned and played on a standalone DVD player, do not.
I was suspecting it had something to do with my slow computer speed (P3 750) but one confounding factor is that it appears that the longer the original MPEG-2 clip, the more likely sync is to be lost (whereas if I use shorter individual clips, sync is not lost).
Ideas?
I'm actually having the exact same problem. The audio is fine at the beginning, but looses sync about half way through.
I had this happen on the last disc I tried to author. It had 4 tracks, 3 were 18 minutes and the last was 40 and all 4 lose sync.
Hopefully someone else has experienced this and can give a solution.
Thanks in advance.
Rob -
I'm going to try a lower audio bitrate tonight. I was just reading-up on VHS quality and video capture bitrate and I might try a lower video capture bitrate, too (e.g., 4000 - 6000 VBR instead of 6000 - 8000 VBR which is what I was doing).Originally Posted by rtwight
I'll post about the results.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 17:24 -
Normalize Audio with TMPGEnc DVD Author 3?
By jonas more in forum AudioReplies: 2Last Post: 16th Oct 2008, 21:10 -
Background audio with still image on TMPGEnc DVD Author?
By tikigod19 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2007, 13:44
