I've downloaded a DTS trailer from site. I want it to convert into wav file. How can I do this and which software can I use. It is played in media player but no sound is heard only video is seen.
I don't believe you can.
The reason why you cannot hear the DTS track is because you don't have a dts decoder. -
PowerDVD comes with a software DTS decoder so you can playback DTS audio on any PC - no hardware decoder required. Given that, a solution would be to hook your sound cards' speaker port to your soundcards' AUX in port, play the movie, select the audio DTS track and record using any decent audio software like: Goldwave, Adobe Audition/Cooledit, Soundforge etc.
You wil need to purchase a stereo min din plug to mini din so as
to hook up your sound card. -
there's a program calleed dts2wav.exe , maybe it's what you're looking for? i've never tried it!
Here it is but it's a DOS command,I don't know if there's a GUI: http://hypercubemx.free.fr/html/download1.htmlOriginally Posted by timmmay
BTW...I would use Audacity to record the sound to WAV/MP3.In MS volume control go to "Recording" and select "Stereo Mixer" or "What You Hear".
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 05:02 -
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 15:20 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 02:06 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 03:23
