hi im trying to convert a movie it is layer 2 so i can convert on dvd2one..
ok the problem is when i get too 52% on dvd decryptor i get a(unrecovered read error) ( abort retry ignore) i keep retrying but still get the same error.. any advice what to do, ive cleaned the disc and ive tried 3 times, and get the error at the same point every time 52% do i just ignore and try and complete and what r the chances of it being a coaster thanxs
Results 1 to 11 of 11
Sounds like you have a scratch or other imperfection. You can choose to ignore the error which may result in viewing problems with your disc. It may be as minor as a simple skip. Once you've ripped the disc, watch it with PowerDVD (or equivalant) to see if it is worth burning.
Do you have two DVD read drives? If so, try to rip the DVD in the other drive... Ive had a similar problem in the past, and the fix was that simple.
this is what the lod file says
I 19:31:46 DVD Decrypter Version 3.1.9.0 started!
I 19:31:46 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 1)
W 19:31:46 Drive C:\ (FAT32) does not support files > 4 GB
I 19:31:46 Initialising SPTI...
I 19:31:46 Searching for SCSI / ATAPI devices...
I 19:31:46 Found 1 CD-RW, 2 DVD-ROMs and 1 DVD±RW!
I 19:41:19 Operation Started!
I 19:41:19 Source Device: [1:0:0] LITE-ON DVDRW LDW-811S HS06 (D
I 19:41:19 Destination Folder: C:\Documents and Settings\paul\Desktop\gony\
I 19:41:19 Detect Mastering Errors: No
I 19:41:19 Fast Error Skip: No
I 19:41:19 File Splitting: By File
I 19:41:19 Multi Angle Processing: No
I 19:41:19 Remove Macrovision Protection: Yes
I 19:41:19 Stream Processing: No
I 19:41:19 Copying VIDEO_TS.BUP... (LBA: 31492 - 31497) - KEY: N/A
I 19:41:21 Copying VIDEO_TS.IFO... (LBA: 309 - 314) - KEY: N/A
I 19:41:24 Copying VIDEO_TS.VOB... (LBA: 315 - 31475) - KEY: N/A
I 19:41:39 Copying VTS_01_0.BUP... (LBA: 3915407 - 3915440) - KEY: N/A
I 19:41:47 Copying VTS_01_0.IFO... (LBA: 31498 - 31531) - KEY: N/A
I 19:41:47 Decrypting VTS_01_0.VOB... (LBA: 31532 - 127922) - KEY: CB 0C 0A B0 00
I 19:42:35 Decrypting VTS_01_1.VOB... (LBA: 127923 - 652194) - KEY: CB 0C 0A B0 00
I 19:45:18 Decrypting VTS_01_2.VOB... (LBA: 652195 - 1176466) - KEY: CB 0C 0A B0 00
I 19:47:24 Decrypting VTS_01_3.VOB... (LBA: 1176467 - 1700738) - KEY: CB 0C 0A B0 00
I 19:49:11 Decrypting VTS_01_4.VOB... (LBA: 1700739 - 2225010) - KEY: CB 0C 0A B0 00
W 19:51:47 Failed to read Sector 2076400 - Unrecovered Read Error
W 19:51:47 Skipping Sector 375661 - Pack Header Not Found -
ok just done a different dvd and this worked fine the 1st must be scratched but it looks like a mirror ?????? any comments would be welcome thanxs again
Clean the source disc. Even if it is brand new out of the package, it could have a microscopic bit of crud on it, preventing the read. Recently I had to clean American Wedding 4 times (right out of the package) before it'd rip.
ive cleaned it with a lint cloth are there any solutions as to clean discs thanxs
i think vicodin was saying to try ripping the disc in another dvd-rom/rw drive.Originally Posted by winny22
If you can, try and rip it in your writer as opposed to your ROM drive.
I always get a more reliable read from my writer when the disc is not in pristine condition."Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
"But you do have all the characteristics of a dog Gary...all except loyalty." -
i only have one dvd drive LITE-ON DVDRW LDW-811S [CD-ROM drive]
and one cd writer drive LITE-ON LTR-24102B [CD-ROM drive] -
flashed the firmware that worked it reads it all now and no burn errors either
Copying DVD's with Shrink and decryptor
By LeeRobertE in forum DVD RippingReplies: 6Last Post: 26th Feb 2011, 14:46 -
DVD Decryptor with newer protection schemes?
By Huh...What? in forum DVD RippingReplies: 7Last Post: 26th Aug 2010, 08:34 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
DVD Decryptor Error Massage
By pchan in forum DVD RippingReplies: 13Last Post: 18th Jun 2009, 13:37 -
SONY AW-Q170A Ripping tops out at 3x with DVD Decryptor
By alwayssummer in forum DVD & Blu-ray WritersReplies: 3Last Post: 29th Oct 2007, 18:08
