    Aug 2001
    New York
    Hey All,
    I need to reinstall my drive, but missing the driver for W2K. Does any one know where can I download it from?
    The problem I have is very strange. The drive is registered in the device list and reported 'working properly', but windows explorer lost it. It happened after I installed w2k sp4 and latest upgrade to the Nero 5.5.
    Any help is greatly appreciated.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    no driver required
  3. Go to google, type in dis-appearing cd drives. You'll find instructions to fix it.
    Try this... http://www.dvdrbase.com/showthread.php?t=547
    2 DVD, or not 2 DVD, that is the question.
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you could try listing it in the device list again and removing it, this way when you reboot it should reinstall it but I doubt this will fix it
    I lost my drives one time and it was because I had installed Nero 6 along with Instantcopy 8. After uninstalling IC I lost all my drives as only my HD's showed in Explorer etc and not my actual CD/DVD's
    I think this was one of the links I used but I'm not 100% sure as I think this was for writing issues , but missing drives was part of the problem also
    http://support.microsoft.com/default.aspx?scid=http://support.microsoft.com:80/support...NoWebContent=1
    :edit: it looks like it the same thing cim suggested in his link also
