  1. Member golfnut's Avatar
    Sep 2003
    After shrinking and ripping DVD9 to hard drive using DVD Shrink is there a way to check the files for errors prior to burning to DVDR? Thank you for your help.
  2. Member Treebeard's Avatar
    Aug 2002
    You can play the files in PowerDVD, to make sure you got what you wanted.
  3. Originally Posted by Treebeard
    DVDInfoPro will do this.
