I've been using a tv card to capture an old vhs home movie that I want to burn to dvd I capture it to AVi fine then encode it with TMPEG thats fine but as soon as I author it with any author (tmpeg,ulead,spruce) the sound is always out of sync.
I've tried splitting the audio and video files but that doesnt work either
any suggestions on where I'm going wrong can it be done with the software I'm using
Are you sure the sync issue happens directly after burning?
Are you watching the DVD-r on your standalone DVD player or on the PC?
If you're watching it on yoru PC only, what software are you using to playback the DVD?
If you haven't already I suggest you watch each aspect of your process, ie. after
1) capture (avi)
2) encode (mpeg)
2) burn
Ideally with something like PowerDVD.
Bill -
Originally Posted by dim.reaper
I know it's unlikely but it might just be okay.
Other than that I'm sorry, I've been no help, I'm out
Bill
Sound out of sync in Avidemux
By Lambert in forum EditingReplies: 21Last Post: 19th May 2010, 00:59 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
