hello i am trying to make a dvd copy of nemo. but all when i use dvddecryptor to ripp the files it wont rip all of them, i will get an error message about not being able to read the blocks on some of the files. i have used dvddecryptor before and it has always been good but it will not rip thi dvd? it is an usa region dvd if that makes a differance i dont know but all others were ok, is there another way to rip or copy thisdvd please?
The only reason I'm using DVDdecryptor now as opposed to Smartripper is smartripper couldn't rip one of my disks where DVDdecrypter could.
My point?
As flaystus touched on, sometimes some software works where others doesn't.
Strange, I could never explain it but it's worth a shot (but again, like flaystus says, the first cause is generally damage).
You could also try CloneDVD (I think that's it's name).
Good luck
Bill -
i had the same problem with bruce almighty. i'll try either smartripper or dvdclone tonight and post the results.
Just do the Movie Only with Nemo and DVD Shrink.....the extras are pretty lame anyway..
Help with ripping
By kuasd in forum Video ConversionReplies: 5Last Post: 26th Oct 2011, 07:57 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
New, have some ripping Q's
By RooD in forum Blu-ray RippingReplies: 3Last Post: 10th Dec 2010, 10:57 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
ripping help
By merkzilla in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2008, 21:38
