Hey there,
I have already read with much enthusiasm some of the previous posts but has not helped me ...
MANNNNNNNNNNNNNNNNNNNNNNNNNNN,
I also get the choppy display... i have a 25fps PAL DivX movie that i want to convert to SVCD
I use the PAL template in TMPGenc then save the Project file.
I use the VFAPI'd AVI file in CCE and have tried checking the UPPERFIELD FIRST and unchecking it????
BUT still no go the display is still choppy.
I dont know where to go from here... any other setting in TMPGenc possibly? or CCE ?
The DivX playes perfectly.
PLEASE HELP......
Where are you, if you are in the US and trying to play back a PAL SVCD you can have problems. Please elaborate more on you r process and playback tools.
im talking about playing in software with WinDVD... region is not an issue here.....
I am using the usual method i use TMPGenc to set the settings for the movie then save the project file.
I then use the VFAPI utility to save the FAKE avi.
I load it up in CCE and set my settings as mentioned and encode.. what more do you need to know. -
Have you tried using the de-interlace function in TMPGEnc before saving the project? I've only had to do that when doing some of the "extras" on certian DVD's, but it's worked wonders.
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
videos choppy on external vga display
By sitlet in forum ComputerReplies: 6Last Post: 22nd Feb 2009, 18:34 -
Help With Choppy DVD
By hgsouth in forum Authoring (DVD)Replies: 7Last Post: 12th Apr 2008, 23:18 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 22:32 -
DVD is choppy!
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 11th Dec 2007, 21:56
