Hello,
I used Decryptor to backup a DVD movie but the files created on the harddisk after it had finished was over 8 GB, hence too big to fit on one DVD-R.
My question is how do you backup a DVD movie using Decrptor so that you can burn it on a single DVD-R (4.7GB).
Would I have to use another software to do this...??? I was hoping I could use only one software to do everything.
Any feedback would be greatly appreciated, negative or positives.
Thanks in advances.
If you're using Nero 6, Nero Recode 2 will automatically compress the files. Or you can use DVD Shrink. Take a look at the "Guides" section (along the left) for numerous hints. You can also go to Doom9.org for more how-to guides....
I would go with dvd shrink, a nice easy straight forward solution.
Russ -
Originally Posted by LeoNapier
Ditto, DVDShrink is a great programme.
You won't need it, it's very simple to use but just in case there's a guide here by mrbass, who I think is a member of this site
There's plenty more guides here.
Bill
What is the best way to putt all my DVD to my Hard Disk?
By DVDhook in forum DVD RippingReplies: 4Last Post: 22nd Apr 2009, 05:00 -
HELP svcd2dvd output too big for a dvd
By scaffers in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Nov 2008, 13:42 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48
