I use TMPEGEnc DVD Author. Sometimes i get this error
not correct resolution 480x480 etc... is there a way i can tell if the file that i'm going to download is ready to be author with TMPEGEnc DVD Author or will i have to encode with TMPEGEnc plus?
I take it you are downloading from Kazaa or somewhere. Unless there is something in the filename you will not know. You will need to reencode to the correct resolution.
However if you are using Kazaa make a copy of the file while it is downloading and open it in virtualdub, go file details and this will tell you the resoultion. This will only work on p2p where it downloads the file in it's proper format from the beginning not like mule or donkey which downloads in parts. -
Just gotta take your chances and re-encode since they are free to begin with.
no reencoding is needed! that's a waste of time!
there is a patcher programme that sets the frames of your mpg file fast to 720x576 or any other resolution you want.
Then after making the DVD you use the same programme to set the
resolution back to 480x480.
It's fast en you will get no quality loss. The actual resolution is not
changed, only a a few bytes per frame are set and later reset.
I think the link to that programme is somewhere on this site, under tools.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 19:32 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
