Hi there,
I sorry I know this has been posted before but I cannot find a solution to the problems I am having.
Firstly, Initially I had no problems with the drive which I purchased 3 months ago. about a month later I reinstalled Windows XP Pro and have lost nearly all features of the Drive.
Here are my problems:
1 Cannot read certain DVD's ( commercial )
2 Cannot read any BURNED DVD-R'S ( except those which I myself burned previously on this drive )
The other DVD-r's have come from a friends machine and work on his and on my DVD player. ???
3 Cannot read DVD's that come with PC FORMAT OR ANY OTHER MAGS ??
4 Can run and install everything from CD format media.
5 Can read and Play audio cd's
I have installed all WINDVD and Power DVD software so it's not a codec issue.
I have installed the latest firmwares ( 1.08 (2) from Herri after the 1.09 official ones didn't make any difference either) .
I orginally had my DVD/R as secondary master ..but changed it to primary Master as I read somewhere that should make a difference....
all with no joy...
I'd greatly appriciate any help you may offer.
The only thing I have not done is a lense cleaner ...but as it's so new I didn't think that could be the reason.
I must add normally the DVD cannot be even found in the drive..but if I GET alcohol 120% to make an image of the DVD it can find it ..but gets read errors at every step ? The disk is perfectly clean with no scratches.
Results 1 to 1 of 1
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
Reauther dark OEM DVD. Help! Please!
By p71rock in forum Authoring (DVD)Replies: 10Last Post: 26th Jun 2009, 00:46 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36 -
Are there any methods to get a Ford oem Navigation unit to play dvd video?
By marc32 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 23:11 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
