im looking for a all formats player that can sync audio..
many times when i see downloaded stuff its out of Sync, and i realy hate that.
i whant to play it, and be abel to sync it when i play it..
like many times its a 0.2 sec delay that is needes to have audio and video playing okay. but no players can do it ive seen ;(
so so sad..
do any of you out there know of a player that can do this?
No player can adjust an audio sync error, you must adjust this yourself before you create the dvd.
"you must adjust this yourself before you create the dvd"
im not taking about DVD's
just normal files like avi. Mpg. Divx and xvid encoded files...
there must be a solution for corecting the audio..
its not me that makes the files. im trying to see them..
like 75% off all the files out there are out of sync
typically, two types of sync probs:
1 - progressive (gradual loss as clip progresses) - nearly impossible to repair.
2- offset ahead/behind by fixed amount - can be repaired
no magic bullets or single proggies to one-click and fix.
suggest starting here:
https://www.videohelp.com/guides.php?howtoselect=5;22 -
I am having issues with Media Player Classic (6.4) not playing AVI/MPG's with the video/audio in synch. At first when the video file starts playing, they are somewhat in synch, but after a while (or after advancing/fast-forwarding the video) the audio/video are WAY out-of-synch. However, Windows Media Player9 plays them just fine. Would this be a codec issue? I have tried just uninstalling all codes but what I need (xvid 1.0 - plus MPG2 codecs) but MPC still cannot seem to play them properly.
Not impossible, it just takes a bit more work.progressive (gradual loss as clip progresses) - nearly impossible to repair
http://club.cdfreaks.com/showthread.php?s=&threadid=59487Cheers, Jim
My DVDLab Guides
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
