I use nero to convert my avi's and burn them to vcd.
Only problem is the avi's are originally wide screen and after the conversion the vcd is full screen and the image is stretched vertically. any suggestions![]()
*Alessandro
My suggestion is dont use Nero to encode, like zippy says try tmpgenc.
I tried using Nero to re-encode a divx movie back to dvd. I know, I know, use Tempgenc, but that's not my problem. When it comes time to burn the project to dvd (I am using dvd-video), it tells me there is not enough space on the disk. Project size is 4.28 gig, so there should be enough room. I am using TDK 2x dvd-r to burn to with a Pioneer A06.
Any ideas or suggestions? I'm trying to avoid forking out money for Tempgenc.
TANSTAAFL -
Prot
I have the same problem - Ahead's site give the below as the cure, i dont know if it works yet as i am having other issues at the minute.
Good luck
5. Nero Reports: "Not Enough Space To Make Copy". Why?
One possible solution is:
Under Windows 2000/XP, please uninstall Nero from your system using the Control Panels Add/Remove Program feature, and then delete the Ahead folder from the C:\Program Files directory.
Remove all traces of Nero (and Ahead) from Program Files and Winnt directories.
And remove traces of Nero in "Setupadi.log" and "apcompact.inf" and edit these out. Reboot and Reinstall Nero and it should now work.
[/quote] -
*Alessandro
Nero Vision TSmuxergui converting MKV files
By vieya in forum Video ConversionReplies: 1Last Post: 30th Nov 2009, 11:47 -
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 19:09 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 19:41 -
converting nero video files to wmv
By chuckaug in forum Video ConversionReplies: 3Last Post: 11th Oct 2008, 12:18 -
Converting with Nero Ultra 7
By Nitro89 in forum Video ConversionReplies: 5Last Post: 21st Jun 2007, 12:42
