New to this VCD making and just want to know if it's better to use DVD2AVI and encode using TMPGEnc OR Flask and encode with the Panasonic MPEG Plug-in?
Right now I'm using Flask/Pana combo cuz I don't feel like going the extra step with the AVIs. But if I'll get better results using DVD2AVI and TMPGEnc, I'd use that.
Or is it all just a matter of preference. I'm sure both ways do a good job.
Yes, it is just a matter of preference. But using dvd2avi and TMPG there is no extra step with a temporary .avi.
to avoid another "quality" argument/discussion...just do it both ways, experiment a lot, take time find what is right for you, only you know whats good to you.
<font size=-1>[ This Message was edited by: Kdiddy on 2001-10-18 14:57:33 ]</font> -
There is actually little difference in quality between Flask and DVD2AVI themselves (with the appropriate settings). Do a short clip to uncompressed AVI to convince yourself.
The main reason to use one over the other are the features in the proggies and speed. DVD2AVI path is definitely faster.
FlaskMPEG is slower, but there are never A/V sync problems, subtitling (hard-encoded) is foolproof and no frameserving is required if you use the Panasonic MPEG plug-in (i.e., it is convenient).
If you want to use TMPGEnc though, DVD2AVI is a better option.
Regards.
Michael Tam
w: Morsels of Evidence
Best utility and procedure to modify DVD
By cryptowiz in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2011, 08:59 -
HD video to DVD procedure
By feh in forum Authoring (DVD)Replies: 5Last Post: 9th Aug 2009, 23:48 -
Cropping Video (Best procedure) ???
By Datahead in forum EditingReplies: 5Last Post: 7th Jul 2009, 18:53 -
Help the specified procedure could not be found error
By mn072065 in forum ComputerReplies: 6Last Post: 7th Oct 2008, 21:14 -
New posting procedure for videohelp?
By yoda313 in forum FeedbackReplies: 7Last Post: 16th Aug 2007, 01:21
