Ok, here is my problem, would someone please let me know if there is a solution. Im trying burn a VOB file to a dvd using Nerovision, orginally when I would put in the file, Nero would say its an invalid file. So I updated the version to the newest versoin of nerovision. Now when I put the VOB file in, it reads it, but says its 0 seconds long. Now i can play that same file using Elecard mpg player or any other dvd playing program. I try it with a different VOB file, and it says that its only 45 min long when it should be 1 hr 15 min long. Can anyone please help with this?
Thanks!
You are burning this as DVD Video under Nero aren't you? If not, you may run into problems. I did...
Yah I am burning it as a dvd, i guess i need to figure out how to do the VIDEO_TS folder.. i have no clue at this point
Authoring programs
By countmonster in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2011, 08:59 -
the sound in my converted videos IS there, but some programs wont play it?
By extent in forum Video ConversionReplies: 8Last Post: 30th Aug 2010, 17:38 -
Disk wont read
By rheming3 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Dec 2008, 02:03 -
Authoring programs for Mac
By turbochargedRS in forum MacReplies: 8Last Post: 13th Mar 2008, 00:42 -
Captured audio from .mpg file can't be seen/read by many programs!
By omnikai in forum AudioReplies: 4Last Post: 16th Sep 2007, 15:09
