does anyone know if it is possible to unlock the DVD region on a player. i've seen software that does it to a PC DVD drive but that isn't helping me. I got a copy of a movie and it won't work on my home player but works in my PC drive. Its not the disk cause another movie i downloaded works fine. The DVD player gives me the message about DVD region it states in the instructions. Also i went to see both movies in the theaters twice and i fully intend to purchase both when they are released cause a screener can not take the place of a full version quality or content wise. this is just a way of holding me over for a few months till they are released. nothing wrong with that since they got my money and are getting more in the future. if anyone can help me please let me know.
What player is it ?
Some players, like Sony for example, need chipping as they can not be unlocked with a remote control "hack". -
yeah its a sony model. the remote hack didn't work. i don't know much about chipping so i guess i'm out of luck. i was thinking of trying DVD region free software cause i'm hoping it allows you to burn the DVD region free so it'll work on any DVD player. i tried hooking my laptop to my TV and play with PowerDVD but it wouldn't show the movie on the TV screen. only on the laptop. i just had the powerDVD player thing on my TV and a black screen. hmm.
If you're ripping and burning a DVD then most rippers will remove region coding. No need to hack your player and no special "region free" software required.Originally Posted by jasonspeed
You need to enable the video output in windows.Originally Posted by jasonspeed"Art is making something out of nothing and selling it." - Frank Zappa -
ZippyP. wrote
It's true that programs like DVD Shrink will remove the region coding.If you're ripping and burning a DVD then most rippers will remove region coding. No need to hack your player and no special "region free" software required.
But you still might have the problem of needing to convert from PAL
to NTSC or the other way around.
The easiest thing to do if you watch a lot of DVD's from other regions is
to get an inexpensive all-region DVD player like the ones from Cyberhome
or Daewoo.
Thomson DV3631 DVD player region code unlock?
By sons1vn2nv in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Sep 2011, 23:34 -
Need Region Unlock for Soniq QMD110GB Portable DVD Player
By Lexx-2 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Sep 2009, 19:10 -
LG HT903 DVD Home Theatre Player Region Hack
By Cyber-Dan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Apr 2009, 09:36 -
How an hacker works to unlock a new dvd player to make it region free?
By bporric in forum DVD & Blu-ray PlayersReplies: 6Last Post: 20th Jul 2007, 17:11 -
region-free unlock help (dvd player not on list)
By pbure0110 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jul 2007, 15:50
