Please bear with me as I've only been doing this for a couple of weeks.
I opened up a cartoon avi file in G Spot, and it says the bitrate is 1322 KB/s. I would like to convert it to a DVD file. I understand (after reading the conversion tutorials several times) that I need to use certain encoding software. I'm using TmpGenc and TmpGenc DVD author.
I'd like to know, since the incoming bitrate is 1322, do I need to encode at a bitrate higher than 1322? I don't think I do, but I'd like to get a more informed opinion.
Thanks!
Mpegs require higher bitrates to maintain quality compared to typical divx/xvid avi files because they use completely different compression schemes. How high? Depends on the resolution you select and and the encoding method - CBR or VBR. The resolution you select should be matched to your source either 352x240,352x480 or 720x480 for an NTSC DVD. Rough bitrates could be 1250, 2500 and 5000 for the three resolutions but that can be lowered quite a bit if you use VBR. You will need to do some encoding to find your preferences though. Hope that helps.Originally Posted by FlyerNut
Newbie Video Quality Question
By tabutcher in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2011, 21:48 -
very newbie question about converting video.
By br9541 in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 22:34 -
DVD5 audio/video bitrate balance question
By Brent.M in forum Video ConversionReplies: 8Last Post: 26th May 2009, 11:38 -
Newbie question on video stutter . . .
By wyldberi in forum Newbie / General discussionsReplies: 12Last Post: 3rd Feb 2009, 17:14 -
video bitrate quick question
By kita in forum Newbie / General discussionsReplies: 16Last Post: 22nd Nov 2008, 01:34
