  1. what is the smallest file output.....i.e. mpeg. I need to put a bunch of video files ( avi and mpeg) onto a dvd and need them to not use up much space....what would be the best conversion for those files.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    VCD resolution of 352x240 in mpeg1 or 2 using VBR encoding with an average video bitrate of 1000 kbps and audio bitrate of 224 kbps will get about 8 hours on a DVD. It will be acceptable quality, a little below VHS.
    1/2 DVD (mpeg2) resolution of 352x480 will be much better looking. Use an average video bitrate of 1800 to get 5 hours on a disk.
    Your choice.
    PS, you can lower the bitrate further if you need to squeeze a little more but I wouldn't go beyond 20% less in either case above.
  3. I can answer that question as soon as you can tell me the PRECISELY CORRECT amount of ketchup to put on my french fries.
