I have current version of Nero 6 including VisionExpress (2,1,0,4) and I can't capture audio (nor do I hear it before or during caputing) from my TV card from either the TV tuner or the Audio In (using VCR). I "know" everything is correctly connected and the setting are correct in "Sounds and Audio Devices" in Control Panel, both playing and record. I can capture audio when using WinFast PVR, ULead Movie Factory 2 or VideoStudio 7 and WinDVD Creator or WinDVR.
To try to solve the problem I just did a clean install of Win XP Pro and only loaded the current drivers from Leadtek (didn't instal WinFast PVR software) and Nero . Installed all Windows updates, still couldn't capture sound. Installed Winfast PVR software and ULead MovieFactory 2 and they both capture audio, Nero doesn't.
My sytem is AMD 1900+, MSI KT3 Ultra, 512MB, 60GB primary HD, 160GB secondary HD (Where captures are stored), Radeon 9600Pro, Live 5.1 sound card.
Any suggestions?
Cheers
I have the same problem. I think this is a known issue. I just wish Nero would post a solution.
I got a reply from Nero asking for some information about my PC's configuration. They said they were now working on solving cpaturing problems. I'll try to remember to post anything I learn here.
[EDIT]: Posted before seing you already have your record line-in volume set.
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Cannot Capture With NeroVision and Pinnacle 510USB Movie Box
By drtalk in forum Capturing and VCRReplies: 1Last Post: 19th Sep 2008, 21:22 -
WinFast A340 Xbox Capture help
By lj106 in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 13:10 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00
