as a new comer to burning dvd's i am having BIG problems getting started.
For example, i have a file as follows :AUDIO FORMAT MPEG Layer-3,72 kBit/s, 44,100 Hz, Stereo
VIDEO FORMAT 512 x 384, 24 Bits, 45533 Frames, 25.000 Frames/Sec, 116 KB/Sec, DivX codec : (fawlty towers 1/2 hr episode)
and i want to burn it to my dvd recorder, (tried using tmpgenc - ends up no sound etc.etc.) - countless problems for a novice as myself - dvdrhelp seems to be the place i will get answers, but need some guidance to start off with - any help greatly appreciated[/b]
just use the PAL dvd template in tmpgenc is a good start ...
make sure audio is converted to 48khz sample rate (tmpgenc should do this i believe in the dvd template)
load elements into your authoring program and go from there ..
when you say no sound - is this on playing the dvd or before (after encoding)?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
