Hello,
Thanks in advance for any advice/guidance! Is there a tool that can easily tell one what kind of DVD VOB (PAL vs. NTSC) files one is working with? I've searched the forums extensively to no avail. Or does one have to get to the fps rate to tell. If so, is there a tool that can easily tell what fps one is dealing with?
Many thanks for any answer to my newbie question.
Many thanks CobraDMX!!! Just what I needed and you've helped me greatly! Cheers!
What's wrong with newbie questions?
I just found out just now that W2K has a built-in DVD player that plays VOB's from files on your hard drive. DOH!
Software to Scan .ASF files swiftly, easily ?
By abrogard in forum ComputerReplies: 7Last Post: 21st Dec 2011, 17:56 -
Which freeware (or paid tool) to cut easily HD movies (MOV,MTS)in 2 pieces?
By innovator in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 04:16 -
Does anyone know any tool to check if files 'mpeg-2' are faulty?
By sgbd in forum Video ConversionReplies: 8Last Post: 13th Sep 2010, 21:12 -
How to easily convert .ts files to Mpeg2 or DVD
By renzo2000 in forum User guidesReplies: 0Last Post: 25th Aug 2010, 16:03 -
Easily check DXVA compliance?
By Quasit in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 11:21
