Ok guys, HELP.
Way back in the mists of time I downloaded a movie that was too large to fit on a single cd, it was 900mb in size. So at that time I thought I would split it in two and stick it together when I have the technology to change it. I now have!!! BUT I cannot remember how I split it, what I used etc. I do have some help though. I THINK I used virtual dub for when I use G-spot to examine the 1st half of the movie it mentions it in the "Comments" bit on the left hand side. Oh by the way it is an AVI with DIVX 5.0. It says it has a corrupt AVI header, and that the stream type is OpenDML AVI. The first half I CAN watch and hear through VIRTUAL DUB. The second Half tells me it is not a valid AVI file!!! n/a info in every box. nuffing!!! So how do I join them back together???
Thanking you in anticipation!!!
Bigboab5
Bigboab5
Try using NANDUB its like Virtualdub. Or TMPGEnc you can Download both of these in the Tools section. They have guides for both of these tools. Hope this Helps.
How can I glue these parts together? (thanks)
By ramox9x in forum Newbie / General discussionsReplies: 6Last Post: 7th Nov 2010, 12:17 -
HTPC from used parts
By redwudz in forum ComputerReplies: 9Last Post: 27th Apr 2010, 18:02 -
Positioning parts of sub
By tofuguy in forum SubtitleReplies: 8Last Post: 3rd Nov 2008, 11:59 -
Is there a mac program that join parts of a video file in rar pieces?
By VidHunter in forum MacReplies: 5Last Post: 22nd Mar 2008, 07:58 -
Simple yet good... that can join my 2 parts avi video into 1
By mai_hnf in forum EditingReplies: 6Last Post: 8th Sep 2007, 02:59
