Hey,
I use nero 6.3.0.2 and made a dvd video from the .vob's and .ifo's etc, and the original default label is "NEW" i changed it to "BAISE_MOI" because i was told its ok to do so by a tutorial. Burned it just normally, then when it came out it had "rings" on it, like unburned parts in the dvd, i could tell by the color.
Tried to play in powerdvd, said it was region 2 then locked up. Dvddecryptor said there was no region coding..So i used ANYDVD to run it with the region code, and it locked up and wouldnt load at all, crashed powerdvd. Tried to run it in windvd, it started ok, but then locked up about 1/4 through and wouldnt work.
I did a reburn without changing the volume label and now all is good. I've narrowed it to that since i made a cdr a while back and did the same thing and got the same defective burn. It could have been that i ran out of memory but nero didnt say the burn failed (i was running newsbin pro at the same time of this bad burn)
My question is why does it mess up when you change the volume label? If my memory had puked i would have been told by nero, its very good at giving me warnings.
Results 1 to 1 of 1
Verbatim RITEKF1, is this a bad burn?
By kira1985 in forum MediaReplies: 1Last Post: 19th Dec 2011, 09:58 -
Need a free program to burn Music CDs and make all tracks the volume level
By Starry in forum AudioReplies: 5Last Post: 19th Mar 2011, 16:26 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
Please look at these Imgburn logs to see why bad burn
By jimdagys in forum DVD RippingReplies: 4Last Post: 18th Dec 2008, 23:27
