Can anyone recommend a good on-line Catia tutorial?
Cheers People
Results 1 to 9 of 9
Wow, Kind of an odd place to find a Catia question. Do you need V4 or V5 tutorials?
You can try this link for the top ten Catia sites: http://www.tenlinks.com/CAD/MCAD/users/catia/topten.htm
Some may not work anymore but it might get you started.
I've also had some isolated success using the forum at:
http://www.eng-tips.com/
Unfortunately I don't know of any Tutorial sites.
Hope this helps. -
Here is another one:
http://catiav5tutorialmanual.com/
I found it doing a google search for catia V5 tutorials. -
on line training http://www.practicalcatia.com
though catia is some heavy s*** ..
IBM (exclusive world distro) and dassault would be the best bet to get some info on universities with catia courses (its a 2 and 3 year program to learn it all and even then you go out with an internship for 6 months to a year or two year after) ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks everyone, I'll check the links later. My new job involves generating harnesses for Jaguar Cars so I was going to have a play with it for the next few weeks.
Yep it really looks a heavyweight, last night I cranked it up (Version 5) and then thought "right, what now!"
Cheers
Ironballs -
I would suggest strongly in getting at least basic training. But then, depending where your located, there are Catia user groups. Typically its a free membership with quarterly meetings having demonstrations.
That will help you make contacts and start to see what its capable of.
Hope this helps -
Sorry to be a moron but what the heck is catia ?
Catia is a CAD (Computer aided Drafting) package used heavily in the Aerospace and Automotive industries. It's like Autocad on steriods. 8)
Got yaOriginally Posted by Turtle49
Just looking for some advice on creating tutorials
By Dire in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2012, 10:15 -
camera lens tutorials
By janep in forum Newbie / General discussionsReplies: 0Last Post: 19th Jun 2010, 21:40 -
Tutorials for new Mac owners?
By nufanboy in forum MacReplies: 3Last Post: 12th Dec 2008, 12:04 -
Need tutorials for optimal use of ffdshow
By drwho in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2008, 07:17 -
Avisynth tutorials?
By rocky12 in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2008, 23:40
