Dear sirs:
Firs of all let me congratulate you guys for this GREAT forum..
I am trying to improve my VCDs using (as somebody suggested in this forum) the 480 * 480 template + normal vcd settingsthat means i am still stuck with 1150 bitrate). The thingis that the size of the movie turns into a letter box. Can anybody help me with that. How can you make it without distorting the final shape of the movie?
Best regards from Colombia south america
I'll give it a shot. Are u using tmpgenc?? if so you can play with the settings>>advanced>>source aspect ratio.
Just a guess. set it to vga 1:1 and under video, set it also to vga 1:1 or 4:3. -
nope, its OK for the movie to be more letter boxed or streched in 480*480. the end result (if you play it fullscreen, or on your DVD player) will play as a normal file without the letterboxage you see during encoding.
Like i said, just a guess. Checking back I should have said video arrange method = full screen (keep ratio aspect). Sorry.
Thanks, Yeshi. -
NP. yes its true you should always keep your video arrange method as fullscreen (keep aspect ratio). i actually use fullscreen (keep aspect ratio 2)
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 6Last Post: 3rd Mar 2013, 10:47 -
Video Size 720 x 480 to 960 x 540?
By jiuvaro in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2010, 10:58 -
Editing custom frame size video - portrait/vertical VGA - 480 x 640
By PMESKA in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2010, 07:02 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 13:29 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25
