Hey
My first post here so i thought i'd say hi
Anyway
Yesterday i got the Formac Devideon DVD Burner. ive been backing up my mp3s and all is well but now i want to back up my dvd movies and in order for me to do so i must open up apple dvd player and have it access the dvd well when i open apple dvd player it says the correct hardware cannot be found is there anyway i can use apple dvd player with my external formac drive?
thanks
Apple DVD Player doesnt work with external DVD drives without a patch. You no longer need to play the DVD first in order to rip it. Use Hades to get your process started.
Where does one get a patch? I have a Lacie external. I can play DVD movies with VLC, but it doesn't have access to the video acceleration routines for the Mac. If there's a patch I can get, lovely. Hopefully, that patch will also be a portal to IDVD, which is useless for external DVD drives.
Check out this thread for doing what you want with Panther.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Thanks, WW; I will D/L and try it out this weekend. It's a great link.
Here's the tech support e-mail I got from Lacie regarding external drives:
Hello,
The drive is not compatible with Apples DVD player. That software is only compatible with internal DVD drives. At this time it is not 100% legal to watch DVD movies with external drives on Mac computers.
Regards.
LaCie Technical Support
22985 NW Evergreen Pkwy
Hillsboro OR 97124
Pretty amusing, yes? -
Sadly, Pacifist cannot extract the mkpkg, so iDVD4 will not install (probably because I don't have an internal SuperDrive).
Here are my steps:
When I opened Pacifist, and selected "open package," all that I could do was point it to the mkpkg on the install disk. That mkpkg was, in fact, a shortcut alias to somewhere -- but I don't know where (either the hard drive or a hidden file on the install DVD), and I could not find the original with Sherlock.
So, bottom line: I have iDVD4, but can't install it on my graphite iMac G3.
The good news, though, is that at least my Mac recognizes I HAVE an external burner.
If anyone else has an idea as to how I can install iDVD and be able to use an external DVD burner, I'm all ears.You're never alone with schizophrenia. -
Ok, I'll stumble along with my G3 and other authoring programs.
I also tried Pacificst for the Apple DVD Player; all I got was an icon that doesn't launch anything. So I now use VLC in OSX 10.3, and if I REALLY want to use an Apple DVD player, I boot under OS9 (not Classic), and use Apple DVD Player 2.4. Works like a charm.
Thanks for your help.You're never alone with schizophrenia.
Apple's DVD-player doesn't seem to get along with Toast DVD-menus
By HitTheRoad in forum MacReplies: 12Last Post: 11th Aug 2011, 03:24 -
Available Blu-ray drive with SONY VAIO & Apple Mcbook laptops
By vikas.babu in forum MacReplies: 0Last Post: 22nd Mar 2011, 04:52 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
Can I Drive an Apple LCD directly from a DVD player?
By xmiinc in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2009, 20:49 -
Quicktime: native codes in Apple QT player?
By geneaum in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:02
