Results 1 to 18 of 18
  1. Member golfnut's Avatar
    Sep 2003
    Could someone please help me by explaining how I may capture and save screen shots to a file on my computer. I would really appreciate your help and advice. Thank you.
  2. <Alt + Print Scrn>
    -Then open paint and Edit > Paste. There you go!
  3. Member curryman's Avatar
    Jan 2003
    <Alt + Print Scrn>
    Why "ALT", it works by just pressing "print screen"
  4. True Dat, curryman! Sorry for the disinfo.
  5. Member curryman's Avatar
    Jan 2003
    Oh lets not call it "disinfo", maybe alternative is a better word
  6. FYI ...
    PrintScreen: will capture the entire desktop.
    Alt-Printscreen: will capture the current active window.
    A difference that should be noted.
  7. Member curryman's Avatar
    Jan 2003
    ooh, you live and learn,
    well there's something i didn't know,
    Apologies to all concerned for misinforming
  8. Member golfnut's Avatar
    Sep 2003
    Many thanks everyone for the help.
    golfnut
  9. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    You can also try a very good program called SNAGIT.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  10. IF you want more than one screen at a time, and want them in jpeg/bmp/tiff format instead of on the clipboard, Screenhunter is free and great! It has timed shots, and custom prefixes on filenames.
    http://www.wisdom-soft.com/products/screenhunter.htm
  11. Member golfnut's Avatar
    Sep 2003
    Thanks guys, a great help. I must say this is the greatest site in the world. The people here, including yourselves are so nice and responsive, just great. Thanks again.
    golfnut
  12. Please help me .I 've tried Print Screen ,snagit & screen hunter,to capture screen when I show the movie clip by realplayer or media player (i.e .rm, .wmv and .dat), but I could only capture the real/media player skin but not the movie image. I don't know what's going wrong...
    Is there any software that I should install besides paint shop which comes with WindowXP Home Editon bundle.
    Your advice is most appreciated.Thanks.
  13. Your problem has to do with hardware acceleration and having it enabled or not. I forgot how you fix it but I'm sure someone here knows.
  14. Thanks g_shocker182.Somebody help me please.
  15. i'm not sure if powerdvd will play wmv files, but .dat (i'm assuming vcd) can have frames captured through powerdvd.. just click the little camera icon. i believe by default it will capture the frame to the clipboard, but you can have it capture to a .bmp file if you mess with the settings in powerdvd.
  16. BSPlayer can capture frames of a video file, but it depends on your Dshow VFW filters whether thye come out right.
    Apr 2007
    Canada
    Here is a good guide on ScreenHunter www.wisdom-soft.com site for capturing video screens from your player,
    http://www.wisdom-soft.com/products/screenhunter_2.htm#movie
    Yep, ScreenHunter Pro is highly recommended from my buddy.
    http://www.wisdom-soft.com/products/screenhunter_pro.htm
  18. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Download this. Captura is a standalone EXE file. Download to your desktop, double-click on the icon, and you can save a section of the screen (or the whole screen after a short delay) in JPG format.
