  1. I have a .cif (easy cd creator) SVCD image file (created with I-Author). I want to burn it on a CDR.
    Who knows how to do this right?
    Burn it with Easy CD CReator 4.x, by selecting open burn from image file or convert it to BIN/CUE with CDMage and burn with CDRWIN/Fireburner.
  3. If you have roxio ez cd creator select data cd project from the project selector menu. When the data cd project window loads select the file menu. On the file menu select (record cd from cd image). Then a dialog box will pop up and ask you for the location of the image file that you want to burn to cd. Once you find the file that you want to burn click on the file name and select open. Then the (record cd setup) screen shows up. Select the options that you want to use and tell it to burn the cd. You should have no problems.
  4. Ok I tried Easy CD Creator 4.
    I can choose between Track-at-once and Disk-at-once.
    When I choose Track-At-Once all goes fine! I have a nice SVCD.
    When I choose Disk-At-Once I receive an error message (at the end) that the data was incomplete. And I have a nice coaster.
    I converted with CDMage and burned with
    - CDRWIN: Result is an unreadable cd
    - Fireburner: Track-at-once=OK, Disk-at-once=Not OK
    I prefer using Disk-at-once because I would like to burn on 90min cd's.
    Who can help me with this? Is anyone using Disk-At-Once with success?
