I wan't to convert vcd into avi (due to size/space problem)...I tried it using VirtualDub but the size is not reduced (hardly by 5-7%) I wan't atleast 35-40% reduction in size..any suggestions??? Plz help.
TIA
First, I think you posted in the wrong forum. I believe you should have posted in the newbie/general questions one.
Now to your question:
The VCD is encoded at a bitrate that usually is 1150kbps for video. To decrease the size you need to encode to a lower bitrate than that.
Generally, you can get a size almost 1/2 of the VCD using DivX or Xvid codecs. You need to specify the bitrate or quality level accordingly.
VirtualDUB is a good tool to do this.
If you have DivX installed, select it in compression within VirtualDUB and configure it for 750kbps or a quality index of 3.The more I learn, the more I come to realize how little it is I know.
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 00:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 20:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 06:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
...Thanks for the tip.
