  1. Hi all,
    I'm looking for the easiest way out of this . I probably could figure it all out with some research but it's not that high up on my list of things to do today.
    I have a VCD with three television episodes on it but no menu. I want to copy it and add a menu. Accessing the episodes with number keys would be fine if that's all that is possible. I really just want a menu screen instead of having the first episode play automatically on load and the ability to see the episode titles and choose one.
    Any help is much appreciated.
    Thanks in advance,
    Dane
    strip the mpgs from the vcd with isobuster, vcdgear or vcdeasy
    author and make menus with ulead dvd moviefactory(easiest) or vcdeasy.
  3. Ulead DVD Movie Factory is NOT the easiest.
    it is difficult to use, and fucks up your system files.
    do not install it. it is crap.
    he just wants a simple menu.
    number key assignments is something so simple that Nero can make it...
    I would suggest either that or VCDEasy. Nero would be easier, since VCDEasy will require you to make the menu image yourself.....
    asdf
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    it is difficult to use, and F***s up your system files.
    ROTFLMAO
    It's always funny when someone takes on the administrator!
  5. I do not know if MF3 is any different from MF2 or its brother DVD Workshop, but the VCD menus in these two do not allow you to select a chapter using the number keys on the remote once the VCD is playing, and on some players even the prev/next will not function. I posted a method of overcoming this in This post
    Graham gab2001uk.com
    Moderator, Visual Basic Explorer Forums:
