Does anyone ever have the problem with DVD-Lab where it just closes on its own? I'll be working and all of a sudden it closes itself. Just wanted to see if i'm the only one.
thanks!
I have been experiencing the same problem.
I downloaded the trial version, and had been running the program for about 5 minutes when "Poof", the entire program just instantly closes. I tried rebooting my machine and then restarting dvd-lab, but it continued to happen every couple of minutes. Very strange. This program looks quite nice, but is currently useless to me until I can figure out what is the problem.
Is it just me, or are other people having bad luck with trying to find a stable dvd authoring program. I had earlier installed the trial version of TMPGEnc, and it crashed my machine to the point that I was forced to reinstall WinXP. Fortunately, after the repeated dvd-lab disappearing trick, I decided to try TMPGEnc again, and this time it seems stable. -
I'm going to get Encore. The tutorial on at http://www.wrigleyvideo.com/videotutorial/tut_encore.htm is great. Hopefully it works as well as this looks. It never does for some reason
good luck
Are you running Nview?
Try turning it off and see if fixes the problem?-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!!
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 05:36 -
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
Help Authoring with DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 14th Dec 2008, 23:28 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 13:22 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 11:03
