I am trying to convert an avi to mpg file with TMPG, I get about 3\4 done through the file and then I get and error message saying "Illegal floating decimal point calculation order". Is this a bad file? or is it something I could tweak out with the settings.Thanks.Matt
There's a bad spot in the avi file. If you play it with media player the picture will freeze when
it gets to that spot. I use Virtualdub to get around it. Save the avi up to the error then skip to
the next key frame and save to the end. You end up with 2 or more files(if u find more errors).
Then I convert both files to mpg and join them with TMPGE mpeg tools.
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 15:05 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 14:53 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
