Can somebody tell me what the best program is to FULLY erase a cdrw? I have always used Nero, but I'm not satisfied with it. It doesn't seem to fully erase it, because the VCD's Ive burn on these cdrw keep getting stuck (on screen) when I play it in my dvdplayer.
I dont think thats Nero's fault...any software that does a full erase erases (i think) using an identical method. Anyway, you could try the windows built-in cd erase thing (at least for XP). Right-click on the drive and press erase.It doesn't seem to fully erase it, because the VCD's Ive burn on these cdrw keep getting stuck (on screen) when I play it in my dvdplayer.-Yar, matey!-
More likely crappy RW's. I've got the same problem with some cheap ones that I bought.
Fully reinstalling K-Lite codec pack
By Xpenguin17 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2010, 21:09 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Are they fully hdmi spec amplifiers if they are only 5.1 instead of 7.1?
By yoda313 in forum AudioReplies: 8Last Post: 10th Aug 2009, 22:03 -
Erase/record new program from *middle* of previous recording?
By NoahsMyBro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 18th Nov 2007, 13:55 -
fully hd,hdmi,hd ready
By gunukhan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2007, 14:14
