I have a 4.7GB DVD-compliant mpeg file captured from my PCTV Deluxe. The movie was a scheduled recording from television. I want to cut out the credits from the earlier program and the station fluff before and after the program. However, when I go to cut it in TMPGEnc, it says "Floating decimal point is divided by 0."
If I encoded the entire thing to DivX (which is my intended destination), can't I only cut an .avi on a keyframe? I doubt a keyframe will land right before the movie starts and ends. What are my options?
I tried running it through FlasKMPEG but when the movie file is loaded, instead of normal movies where the entire film is added as a job, there was no job listed. I tried to make one, setting the beginning to the start, and ending to the finish, but the slider bar jumps back to the beginning when dragged to the end.
Results 1 to 1 of 1
Hopefully an easy question about cutting and joining video with Virtualdub
By crumbworks in forum EditingReplies: 4Last Post: 18th Oct 2010, 15:21 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 16:39 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 11:38 -
question about cutting video
By pike8 in forum EditingReplies: 3Last Post: 8th Feb 2008, 09:47 -
Audio cutting question/help
By cowboysroy31 in forum AudioReplies: 0Last Post: 26th Dec 2007, 22:57
