Hmm! I wrote in a few days ago saying that i had a problem with the dvd discs i was burning my project on. My standalone (wharfedale m3) wont play dvd+r discs, yet it plays everything else fine (dvd+rw). However i played the same project on a friends dvd player and it works fine!
I know the problem lies within my dvd player but unsure wat it is.
Any help would be great.
p.s i have set my player to all region.
thanks
Mushy mushkin![]()
Yup.I know the problem lies within my dvd player but unsure wat it is.
Not all players will play all discs. Your player won't play DVD+R discs. See
https://www.videohelp.com/dvdplayers.php?DVDnameid=1787&Search=Search&#comments -
mushkin,
Does your friend has the same make & model (i.e. wharfedale m3) DVD player like you?
Cheers, -
thankyou for your info, barrister it seems to make sense now.
So does that mean i have to buy a new dvd player that reads + & - ? and dvd+r & dvd+rw and all the lateset gumph that is needed?
By the way i forgot to mention the friends dvd player ISNT the same as mine totally different make( 50 years old) lol!
Isnt there anything i can do without having to buy another dvd player? -
No. DVD burners weren't common when your player was made, so functionality is necessarily limited by the physical constraints of your player. Players are cheap now - Target and Walmart have play-everything models for $50.Isnt there anything i can do without having to buy another dvd player?
If your player plays DVD-R and you are otherwise happy with it's performance, then just stick with DVD-R. If you have a reason to prefere DVD+R over -R, you will need a new dvd player.
Err...Can ffmpegx do batch's of files?
By bigjuggler in forum ffmpegX general discussionReplies: 8Last Post: 7th Jul 2012, 22:04 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Gui for dvdauthor ERR: SCR moves backwards from...
By lienny in forum Authoring (DVD)Replies: 35Last Post: 24th Feb 2009, 06:18 -
confused , newbie (more like overwhelmed)
By fordman37167 in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2008, 23:44 -
Newbie confused. PC crashes/does wild when I attempt to record
By rob1974 in forum Capturing and VCRReplies: 3Last Post: 25th Aug 2007, 10:16
