First I wasn't sure where to post this question so here I am (unless given a suggestion).
I have read long and hard to find various ways to burn a couple of svcd's to a dvd. Just finished from what I've learned and it plays right off the bat in my stand alone dvd player.
Howeverthere is artifacting going on and I wanted to get some opinions on what the most likely cause(s) would be. I might add that I burned to a memorex dvd+r 4x (burned at lowest possible speed that nero allowed which was 2.4x).
Any help or suggestions would be appreciated.
Thomas
If it's on your source, problem solved. Well, in that there's not a lot you can do about it apart from maybe re-encoding it with a bit of softening which might make it less visible.
Otherwise I would say it's a media problem, and your standalone is having trouble reading your choice of discs. If it's not the media but looks disc related, make sure the player is happy with the SVCD resolution if you haven't re-encoded it, and that the audio is 48Khz not 44.1Khz. Some players don't care about this, but if it's truly compliant it will throw a strop if you're not using valid resolutions and sample rates. -
I should give a bit more information about the process I used.
1.) Used vcdgear v3.55 to rip out the mpg's from the svcd bin/cue images.
2.) Used TMPGEnc Plus v2.5 to merge the mpg's into one file.
3.) Used TMPGEnc Plus v2.5 to Simple De-multiplex the merged mpg file.
4.) Renamed the .mp2 files to .mpa
5.) Used DVDPatcher v1.05B to change the horizontal size of the mpg file from 480 (SVCD) to 352 (DVD).
6.) Used BeSweet GUI v0.7b2 and BeSweet v1.5b25 to re-encode the mpa file from 44KHz to 48KHz, along with setting SSRC bitrate of 224
7.) Used DVD-lab v1.3 to make simple root menu to start the 2 movies i was putting on the DVD. Then compiled DVD.
8.) Finally used Nero v6.0.0.10 to burn the DVD.
Burner: LG GSA-4040B
Player: Sony DVPNS725P
Thomas
When you use a PC tuner to HDMI TV input, what causes artifacting?
By MarcMiller in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Aug 2011, 21:27 -
Conversion from MKV to AVI/MP4 Artifacting
By SakuyaFM in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 21:41 -
Toshiba DVR610 tracking and video artifacting problems
By ministry88 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 29th Dec 2008, 11:46 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
