I'm converting a XVid movie to SVCD into 2CDs.
When I'm selecting the source range for each part it takes a lot of time for TMPGEnc to display. Seems there is a lot of activity on HDD. After 5 minutes of waiting I can get the screen to select the source range. All this time TMPGEnc is frozen.
The machine is PIV 2.4G, so I'm trying to figure out what's happening.
Did anybody had this problem?
Thank you for your responses,
Dan
Some Codecs and the way they are used will cause problems and delays like that - if there is not say an I frame for one hell of a long time in the source, then TMPGenc has to find the last preceeding full frame and then work forwards to the point you have selected. This can indeed take a very long time to process.
Is the Xvid AC3 ? This is the only time I have experienced this.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
The sound is PCM.Originally Posted by VCDHunter
Another problem that I had with TMPGEnc was when I tried to load an AVI captured with Huffyuv codec - I got the message "File '' can not open, or unsupported", even the codec was installed (I captured with it
). And I had DirectShow with priority 2 (highest). Any thoughts about this?
Thank you Garry for your response; I think you are right. -
Must be a massive AVI then unless you've uncompressed the audio prior to encoding. But I don't know as the only time this happens is when I have AC3 sound.Originally Posted by msdan
Netflix prices going up again, a lot this time
By jagabo in forum Latest Video NewsReplies: 102Last Post: 18th May 2012, 19:00 -
How to crop a time-range using Vobblanker ?
By Sergeant999 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2009, 09:18 -
auto gk takes too long analyzing source
By miguel22 in forum SubtitleReplies: 0Last Post: 18th Nov 2008, 15:01 -
Question about time it takes to backup hd-dvd
By ultraman36 in forum DVD RippingReplies: 0Last Post: 6th Dec 2007, 14:18 -
Media takes long time in intializing
By chankya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 00:10
